Discuss Notification Required? in the UK Electrical Forum area at ElectriciansForums.net
KevinH
I have just completed a (large) new build timber lodge in a customers (large) rear garden and today given it a full test and produced an EIC for it.
The owner says he has not needed building control/planning consent as it is just within the criteria to not need it, even though it is a 4 bed, 60' x 22' lodge!
My question is, as the lodge does not come under building control, do I need to notify them of the electrical part of the job?
This may sound an obvious question to most, but I have not come across this situation before. My thought is that as it is a new build, I will have to notify.
Any thoughts?
You could argue a 'lodge' is not a dwelling and if you can argue its not a 'dwelling' then Part Pee need not apply.
When does a lodge go from being just a lodge to a dwelling ?
It has 4 beds in it, so its a dwelling, in my eyes.
My understanding is that Part P applies to anything fed from one electricity meter if that meter is in a dwelling, or if the meter is not in a dwelling, but serves a dwelling amongst other things.
On the other hand, isn't it the householders obligation to do the notifying, not the electrician, although they normally do this on the householder's behalf?
Sounds like he might be trying to pull a fast one, if as PM and others say new circuits, new CU etc it requires a notification all day long!
By notifying it you might just 'drop him in it' but thats his problem not yours, you are just doing your job.
Reply to Notification Required? in the UK Electrical Forum area at ElectriciansForums.net
Evening all, Just a quick question, I am an electrical maintenance engineer and have 18th edition, inspection and testing and so on, so I get...
Hi all, a very long time I did a swanky grand designs type new build in the middle of nowhere, so in the middle of nowhere that it's a house with...
Hi all, I am a home owner and our builder has completed a garage conversion with the electrician installing a new 4 way distribution board. The...
We have a customer in a large office block with all power in the building fed from an Electrak plug in busbar system. Lots of desks, lots of...
Hello, I understand that from the 15th of June testing and commissioning of vents and fans is now compulsory and that also since last year any...
4K
