Discuss office rewire with individual meters in the Commercial Electrical Advice area at ElectriciansForums.net
Hi folks - if anyone can offer dvice on this matter as i have heard several ways to do the job, so not sure which is best.
I have an office block that i need to renew the wirings ( surface mounted / suspended ceilings etc..
there are approx 18 rooms on 2 floors which i need to rewire - i want each on on its own meter so i can bill them each month. these are short term lease offices. each office will perhaps use on average 1 x 2 kw heater and seversal office items such as pc , printers etc...
I was thinking cheapest and easiest way maybe run 2.5mm twinearth from new board to office (through meter) and back to board - i understand this is doubling up wiring but each office is on its own ring then. any advice? I have been told to run 6mm armoured to each office but that seems excessive as there is no way i would get 18 x armoured cable on the board?
cheers folks
Have a look at manufacturers websites of distribution boards
Many have options for metering outgoing ways
1. I'd suggest you consult a qualified and competent electrician to look at this - it's not just about loading there's also things like cable lengths, disconnection times and earthing considerations.
2. Various metering options exist from having a bank of check meters (could get messy with that many) up to specialist meter units with multiple outlets and digital data sends - again, take the advice of a competent commercial contractor.
3. Alternatively, consider individual key meters in each unit?
Reply to office rewire with individual meters in the Commercial Electrical Advice area at ElectriciansForums.net
We are refurbishing an empty commercial building at the minute and I don't do commercial stuff day in day out so not entirely clued up on...
DNO ripped out antique main incomer/breaker .The guy hated us and himself and everyone else by the end of the job ! . Client going to contact...
I live in a flat in Scotland supplied with an old 2 meter system called THTC where one meter using a time signal supplied heating and hot water...
So, the actual job is on a farm. I think I'll keep things simple at the moment and just ask about voltage drop. I'll come on to earthing and...
