Discuss Open circuit fault on ring in the UK Electrical Forum area at ElectriciansForums.net
What’s the Quickest method of finding exactly where the break in the ring is? It’s on the neutral conductor. Split ring and then join the line and neutral at dB and test between live and neutral at midway on both legs and narrow it down this way?
Yep best way I know
I sometimes do it that way.
Another way, if you are alone in the house, and no-one is watching, and you can unplug everything is to take one end out at the CU and wago each conductor, energise the other end, and then just go around with a socket tester and see what works and doesn't.
If you then do a plug in Zs at the ones that worked, the highest Zs is the closest to the issue.
Or dead test as above but long lead and continuity test from socket adaptor N to one on the N in the DB?
Reply to Open circuit fault on ring in the UK Electrical Forum area at ElectriciansForums.net
Hi guys. Having a weird problem in a house that has suddenly happened. One half of the ring main has 240ish volts (fluctuates of course), and...
Called out to fault on RCD tripping maybe twice in a month for sometime. Did all the tests & found RCD was faulty, Refitted a new Rcd Type A which...
Hey there, Sorry I’ve just joined up. I’m a qualified electrician/Electrical engineer. Recently sat my 2391-52. My question is I had a fault...
Hi all , after some opinions on N-E fault or ring main. After chasing this fault and ruining my bank holiday weekend , ring main IR readings as...
