Discuss optical smoke alarms in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
yes I fit them all the time, But I would always advise a pm to Tazz regarding fire alarms, the guy know;s more about them than anyone I have known to be fair, drop him a pm.
anyone any experience on optical smoke alarms , been told to fit one in a new build along with standard smokes and a heat detector
Depending on the enviroment, will depend on what type of smoke detection should be used. Ionisation smokes are good at detecting smoldering fires like bedding and furniture. Optical are ideal for detection of visable smoke, and reduce false alarms. If you can give us more information on type of system, building etc we can try and advise.
its a BIG house just under 200sq feet
new build , the drawing from architect say heat detector kitchen optical smoke alarm in sitting room which is open plan with kitchen and hall
and around 10-12 smokeys throughout rest of house
How do you get around 10 - 12 on a drawing? surely they are either there or they aint?
Would be an idea to contact the manufacturer of whichever system you are planning to use as I think some are limited to 10 heads max interlinked.
So you are using mains linked detectors, Optical will be the best to used in circulation areas such as landings. If the house has more than 2 floors, then a full fire alarm is required.
Aico can interlink upto 20 firdex can use upto 12 in one link
i usually use brk type ones ground and first floor only
- - - Updated - - -
from memory 10-12
Reply to optical smoke alarms in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
any BS 5839 experts know whether CO alarms should be connected to the smoke/heat alarm system ? after completing an efixx CPD it seems they should...
Hi all! This weekend we have an offer on 8 of our most popular Smoke, Heat & CO alarms from trusted brands! Don't wait too long as these offers...
I've asked a similar question before I think and we came to the conclusion that apart from new houses and HMO's etc there aren't any rules about...
I currently have a home with 7 interconnected, hard-wired smoke detectors. I have a hard-wired heat alarm in the garage that I need to have...
I'm about to order this wired smoke alarm system as it can network but I just went to see how my existing fire alarms are hooked up and there...
