Discuss Overide PIR sensor? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
T
TPES
Hi all
Can anyone confirm i can overide a PIR sensor by switching the switch feeding the sensor on/off quickly, Like you would a security light?
There is a extension being built with about 5 low energy bulkheads around the building lighting up the path around the building, these will be on a PIR so when someone comes out the back door all 5 bulkheads will come on once the pir has picked you up.
The lights will be fed from the ring main on a switched spur.
Will the pir be overided to keep the lights on perm if i quickly switch the spur on/off. or will it depend on the PIR i fit?
this should work the same as a security light but just turn the lights of then back on this will overide the unit . then when ready switch turn of , on of on quickly to reset:)
Instead of having a switched spur, you could use a fused connection unit , then run a feed from a light switch in the house to the outgoing side of the switch on the PIR. ie, the side that goes to the lights. Then you can simply switch the lights on and off, and the automatic detection will still work as normal. I have did this before.
Hi all
Check on the type of PIR you are fitting as most will not work with Low energy fluorescents.
Reply to Overide PIR sensor? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi there, I have an outside light that is turned on with a switch from inside and would like to change it to a PIR version incorporating an...
This weekend at Electrical2Go we are offering the Ansell Prism pro (APRIP/1) for just £6.95 ex VAT ! These are one of our best-selling...
I have replaced a staircase timer because the previous one was fault. There was a problem the light stayed on all the time. When i replaced the...
Hi all, Just a quick one, I want to use an ip rated light switch with a neon indicator to manually ovveride a PIR detector controlling an e27 LED...
Hi. I'm an I.T.. engineer with some outdated electrical experience. I qualified C&G 2330 17th edition about 15 years ago, but my only experience...
