Discuss ow could i lower the power to this unit to make the motor go slower in the UK Electrical Forum area at ElectriciansForums.net
B
beatles2011
Hello, i need some help.
I have this record lathe (below) and it operates like a normal record player but just that it cuts them (records). This units motor runs at 78rpm which is a bit to fast for making records now as at 78rpm i can only cut 3 minutes of music. I want to be able to slow the motor down without having to modify anything inside the unit if possible. Is there any type of device / unit that i can attach between the 3 pin mains plug and this unit so i can slow the power to the motor down which would mean the motor would slow down so i can record more music onto a disc.
Let me know if there is anything and if possible link me to a site which would sell such a device, preferably with a digital screen to lower the power (to make the motor run at about 33 or 45rpm or somewhere around that)
Help greatly appreciated. Pictures attached below. Many Thanks
No, that will probably just destroy the motor. Those basic phase-angle controls only work for certain types of motor, such as the series brush motors in power tools, not for induction or synchronous motors as in your lathe.
The only way you can vary the speed of an induction or synchronous motor effectively is with an inverter / frequency changer as suggested above. However there are important side effects, because you want to vary the speed over a wide range, not just a few % of pitch trim but at less than half rated speed. The motor capacitor would probably need to be changed in value and additional cooling might be needed. The insulation might not withstand short risetime drive waveforms.
This is a job for an expert, one false move and you will fry your motor. It might not be satisfactory overall, and an alternative drive gearing might be needed (I am not sure what the drivetrain looks like in these BSR lathes). Please do not mangle it, some of us still like to cut our records at 78!
start mucking about with it, at won't be worth diddly squat. it's value lies in the fact that it's original.
Reply to ow could i lower the power to this unit to make the motor go slower in the UK Electrical Forum area at ElectriciansForums.net
Hi, I have a project I have been working on, that has me out of my depth with regard to my knowledge, as I am a very basic electronic hobbies...
Hi, First of all I must explain why my posting came to be on this site, I was looking on the internet for a forum that could help with a project...
I experienced an electrical shock while replacing an A/C Fan Coil's 120vac, single phase motor that was above the ceiling grid in an office, while...
4K
Hello everyone In September 2023 I rented a beautiful 3 bedroom apartment, with all electric supply, no gas powered appliances. I noted down the...
