Discuss Panel with Relay and SPD, Installation? in the UK Electrical Forum area at ElectriciansForums.net
Hello and thanks for the interest. I have a little dilemma and was unable to get an answer anywhere.
I'm trying to fit a SPD and an over/under voltage protector to my existing "Main Switch" and "RCD" setup. my question: is the location of the SPD and surge protector correct? thanks
What is the current rating rating of your surge protector? I have fitted Dehn SPD’s at a factory this year and to simplify matters the units are rated for 125A with big terminals so you can fit them without going through a Mcb first and Just off the main switch. If you use smaller cable to connect them then they come off a suitable rated mcb.
It looks like your main switch is in fact a double-pole MCB, is that correct?
Nothing wrong with doing that provided it is appropriate for the load, etc, but it would make selectivity with any down-stream MCB/RCBO very difficult to achieve (unless its instant trip point is above the PFC/PSSC of your supply at that point).
As already said above, many of the SPD are designed to be safe with supply fuses of up to 125A (or more) so you can normally get away with the supply's own fuse and use a simple DP switch. However, if your choice of SPD specifies a smaller breaker then you need to look at the design more carefully.
thanks for the detailed explanation. yes the diagram is of a double pole mcb but as per the text its just a main switch (a manual on/off). the switch is rated as 40a and the spd is rated at up to 60a. the spd is the one below:
  • 1pc-AC-SPD-1P-2P-3P-4P-20-40KA-30KA-60KA-385V-House-Lightning-Surge-Protector.jpg
That is 60kA peak surge current, almost certainly for a 8/20us waveform.
You need to look up the data sheet to see what the maximum over-current protection is, and check that is above the incoming supply fuse.
Reply to Panel with Relay and SPD, Installation? in the UK Electrical Forum area at ElectriciansForums.net
Hello, I was looking at installing a SPD into an existing split load RCD BG consumer unit. In the instructions for the SPD it states that it may...
Hello! I'm struggling to find an answer to this question online. I'm new here btw - I'm a DIYer with a physics degree Currently when my fridge...
Hello, First of all, thank you in advance for any helpful insights posted in response to my question. I have just moved into a new home. With...
