Discuss Pictures of simple jobs done properly. in the UK Electrical Forum area at ElectriciansForums.net
Ended up re-terminating a DB after working on all but one of the circuits, made testing much easier. None of the neutrals or CPCs were in the correct terminals and most terminals were inaccessible as the cables went all over the place. I wish C50 boards were still made. The RCBOs all had really fast tripping times too.
The photo is a bit blurry, I must have been shaking with excitement.
Me like this.
These are the small recessed lights i was on about the other week when I was asking the dimensions of the click flow connectors.
Tel ! 3mm Earth sleeving !! Tut tut. :p
only size my local wholesalers stock. then you gotto buy 10m which then ends up as a complete mess in the van. finally got some 2mm of fleabay. can buy 10m or muliples thereof.
I'm quite happy to carry on with 3mm Tel, as long as it's not the rubbish stuff that creases all over the place. Tend to buy 100m at a time which you can get on a drum now, much tidier and you don't end up with umpteen ends on it. :)
Damn, lost the "after" photos somewhere, upgrading to new switches and redoing the patch panel cables at a company a few years back tidying up a load of comms rooms. The Fluke cable analyser was a godsend as it read the port and switch info.
do you get a jar of dolmio with that?
white bezel... YUK.
and a pendant behind the door would have been more fun. :D
Reply to Pictures of simple jobs done properly. in the UK Electrical Forum area at ElectriciansForums.net
Just had a simple kitchen light not working job, one of the fittings with the 4 spotlights on it. Took the fitting down to check if there was...
Posted from another forum "Pretty easy to spot exactly what type of client you're talking too once you've met and dealt with several, and I used...
Recently been working on a system design for a LL. I was told the building would be a three floor 16 room HMO, so the design was done to the...
5K
Morning All I recently completed my first re wire and board change, (with help from the owner who is a gas fitter and plumper, who works with my...
