Discuss Pilot wire voltages in the Central Heating Systems area at ElectriciansForums.net
F
fjr1300
I've got a problem with heating system I've just installed,
A central 3 zone programmer controls 16 electrical rads via a power manager using the pilot wire system.
There are 3 types on rads, Oiled filled with 5 settings, cheap element with simple thermostat and 2 Towel rail with thermostat control.
The "cheap" heaters work fine as do the towel rail ones, its the more expensive oil filled ones that are causing a problem.
The oil filled ones appear to be ignoring the pilot wire signals. I have a few cheap heaters on the same pilot wire as the oil ones and the cheap ones do get controlled.
Testing by changing from comfort to frost the heater should shutdown - cheap ones do, the oil ones stay fully on
Can anyone point me to a document that has the various voltages on the pilot wire for the various settings IE comfort, ECO, Frost ..etc
I can find loads on stuff on the web about heaters using the pilot wire but none giving the actual voltages.
Lee
Reply to Pilot wire voltages in the Central Heating Systems area at ElectriciansForums.net
Hey everyone, hope you all had a good xmas. Got called around to change over an old style pin type thermostat to a hive one for a family member...
Hi folks, I'd like to get my Nest thermostat up and running with the gas combi boiler (Worcester Greenstar HIghflow 440 Standalone). FYI - I...
I have a Firebird oil boiler that is controlled by a Honeywell timer (no thermostat) that has channels for hot water and central heating...
I've always thought I was quite good a wiring heating systems, I can do Y plan, S plan, UFH set ups, "normal" thermal stores etc, you name it and...
Hi All, I've installed a Lorex doorbell recently, but it is not turning on. I did some tests using a multimeter and this is what I found...
