- Reaction score
- 17,140
as it was a pipe on the heating circuit so all the water would have still drained out of all the radiators through my little hole!
If it's a sealed heating system there will be a safety pressure relief valve on the system, these can be manually operated to rapidly discharge the pressure from the system to outside. Once the pressure has gone from the pipework water should stop coming out of the hole (assuming there is only one hole) as way for air to get in to the system to replace the water which flows out.
If it's not a sealed system then you would need to block the feed and vent pipes at the header tank to stop air from entering the pipework and again it will stop the leak.
