Search the forum,
Discuss Point to ponder in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
the pict
Mentor
Outside cabinet to power private estate street lights, cabinet is suppllied from mains PME,d standard 1361 cut out and independant meter, two way C/U, outgoing cables are 2.5 3 core SWA,
where is the EPZ ? and if within the cabinet,then I cannot take the earthing outside it, if I take it to each lamp in turn (15 in total) I am theoretically exporting the PME or am I
Pict
the lights are part of the installation and so the EPZ extends to all points.
Pict
In fact, you Don't EXPORT an equipotential zone, you EXTEND it!! Low and behold, ...everything actually makes sense then too!!
I'm hoping a simple logical question for one who knows little about this sort of installation, what if there is a street sign fed from a different supply adjacent to a lamp post, how would that effect the situation?
EPZ doesnt really apply to highways power & street lighting furniture in the traditional sense
in a domestic its easy to define the zone by virtue of the property / building and any metallic services entering it that may require earthing / bonding.
but go out onto the public highway with a street lighting circuit that can stretch for hundreds of yards then all gets a bit difficult to establish.
and if you consider metal lamposts to be part of the epz you would need to run 10mm earth bonds to each unit , which obviously isnt really feasable , so earthing is provided by your swa , as is the industry norm.
on the whole i'd say it doesnt really apply to this type of installation although others may disagree.
Reply to Point to ponder in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
  • Locked
5K
About 15 years ago, after having had a modern consumer unit fitted, and prompted by our electrician, I asked my then energy supplier (Tonik) if...
5K
Hi First time with this kind of a job for me. I have a scenario where i am planning to install about 50m 25mm TPN from a TNCS supply to supply a...
6K
I realise this overlaps with the Earth Rod install post a little, but I am attempting to plan part one of an upgrade. Currently I am mostly...
6K
As the user name states, I am not an electrician but I am trying to be an informed customer when dealing with a friendly local sparky and the...
5K
