Discuss Powering electrical components with static charged electricity in the UK Electrical Forum area at ElectriciansForums.net
Danny94
Hey.
I have seen those experiments with rubbing a baloon and creating static electricity to make a fluorescent light bulb glow. Im interested in making a similar experiment but with (gas free) electrical components.
According my research static build up electricity is high voltage low current.
I wonder if there are some electrical components which actually can make use of this electric charge. Like power on a led, charge up capacitor or at least consume the electricity which creates a measurable (multimeter) flow.
Is anyone of you aware of an electical component with mentioned or similar properties ?
Static electricity is in the 10’s of thousands of volts.
enough to destroy most semiconductor components
Short answer no.
Static has been know of for many years.
The only use is for a vandergraf generators in school.
Standing on a plastic box and make long hair sticks out.
Or all standing holding hands and zap the last person
Lots of fun but not very practical
@OnlQQker Yes but im not looking for free power generations as main purpose of this experiment, i want to prevent static discharges by consuming the charge. (witouth earthing the body)
So the actual question is how to prevent static shocks. Well i can tell you how to avoid the ones you get when you step out of a car.
@DPG the question remains the same ;D im looking for a component which can consume the static charge and in the best case beeing a electrical component in form of a led to make it easy to demonstrate, but im fine with every component (as maybe i can measure a voltage drop on the skin, or heat/vibration on the component). The component though should not be radioactive or containing gases or other dangerous things.
You can't consume the charge, the only way to get rid of a static charge is to allow it to flow to earth.
The vast majority of electronic components you could put in the flow will either be damaged by it or do nothing.
The only thing I can think of at the moment that will show a response to static is gas discharge based lamps. As you've already mentioned fluorescent tubes are a good example.
Neon indicator lamps are another example.
Reply to Powering electrical components with static charged electricity in the UK Electrical Forum area at ElectriciansForums.net
We have started a business building garden rooms/caravans/mobile homes under the caravan act. We have only done one so far and I got an...
Morning All I recently completed my first re wire and board change, (with help from the owner who is a gas fitter and plumper, who works with my...
Hi guys, I've gotten AI to write up a terms and conditions for my company and then went through it with AI and tweaked it to make it sound a...
Hope this all makes as much sense as i can make of it and my "problem" can get sorted via some guru on here... Just a quick background on myself...
