Stuart M
Hi Guys I'm not really very knowledgeable about electrics and don't know all the correct terminology so please forgive my ignorance. I wonder if anyone could help resolve a problem I'm having putting up a light fitment in my lounge. The problem (at the moment) is actually to do with the light fitment itself. I bought a light fitment from John Lewis and needed to remove some chain links in the suspension chain of the light (it was way too long). To completely remove the unwanted chain links, I also then needed to unthread them from the cable of the light fitment. To do so meant I had to disconnect the wiring from the terminal block (which came with the light) so I could then slip the cable through the rose (part of the light fitment) to then be able to untread the unwanted chain links. None of the light fitment wires are colour coded so I tried marking the light fitment wires before removing them from the terminal block (with an initial on a piece of paper and attached it to the wire with sellotape). Unfortunately, in slipping the cable through the rose, both the neutral and live markings I had made slipped off. I'm so annoyed with myself as I've now no way of knowing which wire is which as both are silver wiring encassed in a see through plastic. The only thing I have noticed is that there does seem to be some minute lettering running down at least one of the neutral or live wires. I can't make the lettering (coding?) out as it is so small but wonder if this would identify the neutral or live wire of the light fitment? If not, is there another way to determine the wiring given the neutral or live wires aren't colour coded? Obviously, if I'm unable to resolve this problem myself I may try and take the light fitment back to John Lewis as I have subsequently noticed there is a screw missing in the terminal block which means I would have had to transfer the wiring into a new junction box anyway. I hope someone here may be able to help resolve this problem. Thanks.
