Discuss Pump on or is it in the Central Heating Systems area at ElectriciansForums.net
the pict
Mentor
Grant Pro external combi
I have just nipped across from the sparky forum and hoping for some advice, the boiler stopped working this morning however, long story short I have never had the burner out in the 3 years since it was installed and the prongs were coated in black crud a quick clean and it was back working, but on the bank of lights the DHW light is on constant its probably been like this for ever but I have only just noticed it as I had the cover and lid off and the light on the pump is lit too,so do I have another issue
Pict
Oil boilers should be cleaned and serviced annually. The HW light will usually be on all the time as most of these systems will be wired so the HW is always available. The pump will continue to operate after the burner has shut off for a while but should eventually stop once the hot water store is up to temperature and hot water is not being drawn off.
Reply to Pump on or is it in the Central Heating Systems area at ElectriciansForums.net
I've always thought I was quite good a wiring heating systems, I can do Y plan, S plan, UFH set ups, "normal" thermal stores etc, you name it and...
Good evening, I have recently moved into a new home and I am having problems with the MCB/RCD tripping (Mem M6 Type 3 - 30mA). It intermittently...
Im trying to make a Star Wars Prop for a course project where the dealine is comming up very fast in days and I need to do the report so really...
We have this type of "mechanical" timer switch to control our central heating, which is Potterton combi boiler. The switch keeps failing after 2-3...
Hi I have a heatmiser uh4 wiring centre and a grant vortex combi condensing oil boiler, doing the heat and HW in a small cottage, the room stats...
