Discuss R, L, C and Power Question in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
jaydub
Question: Three coils of resistance 40 Ω and inductive reactance 30 Ω are connected in delta to a 400 V 50 Hz three phase supply. The total power will be:
a) 13.31 kW
b) 7.68 kW
c) 9.6 kW
d) 16.63 kW
I now know what the answer is, however, I do not understand how to get there! I would be very interested to see what others think to this.
I will hold back the correct answer for the time being.
Now that is what I believe to be the answer. I also managed to get there using two different formulas.
However, according to the answers, that is not correct! Guess again :D
The answer is apparently B, 7.68kW.
Would anybody be able to explain how to carry out the calculation? I have looked at the PDF Vortigern, but I still don't understand it... :rolleyes:
I thought you had to do this:
Z = square root of (Rsquared + XLsquared)
Z = 50 ohms
400/50 = 8amps
400 x 8 = 3200W
3200 x 3 = 9600W OR 9.6kW
Clearly though, this is incorrect, static zap, can you shed any light?
I found this part of the course I did the most exacting and understood it at the time, however I cannot get my head around it now without serious study and thinking about it. It is a different thing with the tutor there helping you to get through it and as I virtually never used it in general work it just goes away. This is for the industrial electricians I think. I am sure there must be some on here.
Reply to R, L, C and Power Question in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
all currently working towards my 2391 c&g I&T . I know how to calculate v.d. but the mock test I found online seems a bit out of date or I'm...
I will describe my problem in as much detail so you guys might be able to answer my question. I am never home, my Electric bill is $ 28 to $30 a...
Hi All, I am currently learning about AC and DC supplied coil and have been given the scenario below. I understand the first few steps but then...
About 15 years ago, after having had a modern consumer unit fitted, and prompted by our electrician, I asked my then energy supplier (Tonik) if...
5K
Electrical Courses
