Discuss Reference methods in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Sparkydan
Hello
What reference method(s) would be used in a domestic installation?
I have looked at appendix four in BS7671 and the table that covers flat cables only describes cables in stud walls or above plasterboard with thermal insulation but what about cables under ground floor cables and cables chased in the wall?
Reply to Reference methods in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi All I wanted to ask a question about the reference method. Passing wiring through holes made at 0.2-0.4 of the joist span. The cables passes...
Hi All I would appreciate some help with a few questions here regarding cables sizing, I'm using the latest 18th edition, amendment 2. Q1...
Hi, I have two questions about domestic wiring In Ireland 1. Should conduit be used when passing multiple T&E cables (2.5mm) through a garage...
Hi all, I'm planning to remove a stud wall seperating my dining room and kitchen. On the dining room side of the stud wall, there is a double...
