Discuss Repairing damaged cable in wall in the UK Electrical Forum area at ElectriciansForums.net
Sparra
Hi guys, so I attended a property today where the lights were tripping with a neutral to earth fault. It turned out that a week previously the tenant had tapped a little pin into the wall to hang a picture, incredibly he says it's been fine for a week and only started tripping over this weekend. On removing the pin the IR neutral to earth is back to out of range. And rn-r2 is 0.6, only 0.1 higher than the next nearest fitting. But it still needs repairing I hear you say. The cable runs down, where some rather nice solid flooring would be ruined by being lifted. If I replace just that section of cable from the light down to the damage point, how do you all feel about splicing cables and burying them? Does that count as maintenance free? I don't fancy burying a whole mf box.
You could cut a 400mm circular hole above, use Wago Box to joint cable above then run new cable to what is below damage. What is below damage?
The cable in question runs from the damage point up the wall to the first of 2 wall lights. So in this case there is a light above and good cable below.
So I assumed the advise would be to cut out the damaged area and replace the section of cable up to the light.
Sounds like you're advising a wago mf lighting box? I didn't much fancy chopping out the wall in this block of flats, so wondered how you all feel about splice and heat shrink, or even wago spliceline connector and heat shrink which I've seen posted as a solution elsewhere but wanted to ask your view as to whether that's possible/sensible?
You need to end up with two layers of insulation and reasonable physical protection.
Crimps are fine for a joint, but they need containing or surrounding. I’d think self amalgamating tape would be better than heat shrink.
What’s the wall construction, is it a stud and plasterboard wall? That would determine my approach.
(You don’t always have enough give on the original cables to join them up again and get anything around them and a fair bit of wall needs removing even to expose enough to crimp them.)
That's why I don't want to dig much our really, I fear it's concrete. Surely not, but maybe. Plasterboard on top. But judging by how much of the pin was in the wall, there's not a lot of space at all.
Hmm. Hadn't thought of that. The conductor itself has a reading which, incredibly, suggests it's not damaged. Whereas a crimp connection must be good. It's definitely don't want to crimp and leave a connection with worse continuity to what's there already. What's your feeling on using self amalgamating tape over the existing cable and damage? It must just be a pinprick. It provides insulation but not mechanical protection, right? It's hard to imagine a pinprick in a sheath that's been reinsulated with self amalgamating tape being a problem...
As I'm sure you know the trouble with these situations is having to 2nd guess the actual damage.
The IR is good so the conductors are not likely to touch or arc.
The RN-R2 suggests the conductors haven't been partially broken leading to a higher resistance.
If you had a thermal camera you could stick a big load on and see if there's a hot spot showing.
It would be very tempting to let sleeping dogs lie, but unfortunately it needs examining just in case e.g. next week a vibration causes the earth to break.
I'd very carefully cut out a rectangle 1 inch wide, 2 inches tall (without cutting through the cable!), carefully cut away the outer insulation, have a look, and if all is ok wrap the neutral with a couple of turns of insulating tape, and then the whole lot with AM tape.
A bit of MakeGood from screwfix, carefully sanded, and it will be good as new unless it's wallpapered of course, in which case the first job is trying to cut out the wallpaper to reinstate afterwards.
That would be your call. Any joint must be available for inspection, i.e if it fails you know where it is. Wago connectors are only maintenance free, because of the box they are installed it. Putting spliced/soldered joints in a wall is a bit dodgy.
I can't see that being practical all the time and while it would be great to do that, does the regs state it?
All screw terminal joints should be accessible, not sure I’d be comfortable with crimped or soldered joints not, being reliant on the installers skills therein.
Reply to Repairing damaged cable in wall in the UK Electrical Forum area at ElectriciansForums.net
Hi, looking for some ideas on this. I went to an address on Tuesday following a storm where property has been struck by lightning. When the...
Hi all. Sort of an interesting one. I had a call from a client to say she is getting a shock when using the shower. I told her not to use it and...
Hello all, Looking for help here as I've come across a strange call-out today. Bare with me here: Got a call from a customer saying they had...
Morning All I recently completed my first re wire and board change, (with help from the owner who is a gas fitter and plumper, who works with my...
