Discuss Replacing two-way switch with dimmer. in the DIY Electrical Advice area at ElectriciansForums.net
Just to confuse things more, they do make pull cord dimmer switches..... just saying :tearsofjoy:
As has been said, get an electrician, someone who has been trained and knows what their doing before you end up hurting yourself, others, or causing a fire risk.
Reply to Replacing two-way switch with dimmer. in the DIY Electrical Advice area at ElectriciansForums.net
our dimmer switch stopped working after 7 years so went to replace it at the weekend. When I opened it up, the black wire was in the common slot...
Hi, in my bedroom i had a 2 gang dimmer that powered 2 set of 3 spot lights and also had passthrough wires to other sockets. Im changing to just...
Hi all I've been changing the halogen downlighters in my house to LED's. I have three rooms that use dimmers, two of them have two switches each...
Trying to install a Lutron Toggle/Dimmer (TGCL-153PR) Confused, as the current switch has 3 wires gong to it Black, White, and Red (there is also...
Hi :) I'm currently renovating my outbuilding. My electrician has fitted 10 conduit LEDs (that support both leading and trailing edge) and x4...
