A
Andy B
I`m a qualified sparky and I`m re-wiring a house. I tend to do corporate work and haven`t done many house re-wires so I have some simple (stupid) questions.
Is there any particular way the cables should be run ie should you try and keep them all fairly close or can you have cable running off through joists in all directions. Obviously they are going to be hidden once its plastered.
I have been told about "zoning" by another electrician who claimed that the cable should only be run in the wall vertically and horizontally from sockets and switches but cant find anything about it in the regs and had never heard of it before. Does this mean I cant go around a corner onto a wall with no socket to pick up a socket on the opposite wall but instead have to run down and through the joists?
With regards to the installation being registered for part p is it possible to test it all and supply the test certs to the council and pay them to inspect it (how much does this cost?) or will I have to pay a registered electrician to test and certify it?
Cheers
Andy.
Cheers
Andy.
