- Reaction score
- 143
Think I've got it worked out.
Discuss RF Mains link kit on a heating system. in the Central Heating Systems area at ElectriciansForums.net
Hi mate, sorry I didn't reply I've been flat out....If the hot water valve is next to the cylinder along with the cylinder thermostat then you need perm live, neutral, earth, switched live from 6 on heat link to common on cylinder stat, normally closed on cylinder thermostat to brown of the valve and orange to fire the boiler. Where is the heatlink in relation to the cylinder? What about the CH valve...where is this located in relation to the heat link and cylinder?Think I've got it worked out.
Nice one then mate that's basically exactly what I've done, ripped out all the old and wired new. The Heatlink is in the garage next to the wiring ctr newly fitted, the boiler there too and the Htg valve is an old Sunvic / Satchwell there too as the flow leaves the boiler horizontally on pipe there, has a yellow to open on 240, white to apparently close it again. This valve does not work well at all but was logged as fitted in 1983 ! so I plan on Monday to replace with an HPA2 or 4043 Honeywell and spring return.Hi mate, sorry I didn't reply I've been flat out....If the hot water valve is next to the cylinder along with the cylinder thermostat then you need perm live, neutral, earth, switched live from 6 on heat link to common on cylinder stat, normally closed on cylinder thermostat to brown of the valve and orange to fire the boiler. Where is the heatlink in relation to the cylinder? What about the CH valve...where is this located in relation to the heat link and cylinder?
Vented cylinder, and it's sound the other two valve heads fit straight onto existing valve.Yeah I've never really been a fan of momo valves. Don't sunvic make a spring return valve that will directly replace the momo valve head without having to drain down etc? Is the cylinder vented or unvented?
What I would of been inclined to do would be to install a wireless cylinder thermostat, use the twin skin as LNE for the valve and the RF link link for the switched live from the valve. This way everything would be fed from the same SFCU/plug top.
Reply to RF Mains link kit on a heating system. in the Central Heating Systems area at ElectriciansForums.net
