Discuss Roof anchors in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
We had real trouble getting the Cambrian slate out to cut it - any suggestions how we could get it out without breaking every slate? It's held onto the roof with 2 pins rather than normal nails. That's why we decided to use so much lead but leave the existing slate in place. Otherwise it was going to be 70 replacement slates as well as the 10 we broke during the installation - it was like treading on eggshells!
On Slate we ALWAYS use professional roofers, that have a special knife / gizmo called a "Slaters Ripper" ( Toolstation > Digital Catalogue) that slips under that tile and cuts through the pins - nails SHOULD be copper / aluminum, occasionally we've come across bodged jobs where they've used galvanised nails and they can be a pain to remove, patience and experience!
The nails you see the guys putting back in are Aluminium NOT galvanised ..
ALso trimming the slates is done with a specialist tool (http://www.toolstation.com/documents/catalogue/catalogue38/catbox.html?pg=143&code=92704) that nibbles away at the slate and also punches the new nail hole without breaking the slate.
Without expection, we send ALL our new guys away on the PV Installtion course run the REAcademy (Solar Panel Installation Training from Renewable Energy Academy, Specialist Training Providers in Renewable Energy Installations) the same guys that run the Sharp Academy (Sharp Renewable Energy Academy - Sharp) , the courses are expensive, however it pays itself back on the first job with improved safety, more efficient jobs, less mistakes / repairs etc
Gordon
Yep we also always use professional roofers for every job not just slate, the slate ripper just doesn't work with Cambrian slate, it's fine with the others. Our guys have worked on slate roofs in a national park for the last 20 years and are very experienced.
Unfortuntaley Cambrian slate is very different to all of the other types of slate we've dealt with. Most slate is pretty straightforward to sort out with the aid of the usual slate ripper. The problem with the Cambrian slate is that you don't actually put nails into the slate as with other types of slate. It has a plastic lip that the slate sits on and it's the nails (which are more like screws and twice the normal length) that are the problem - they can't just be pulled off in the usual way with the slate ripper and even with patience and 20years experience they don't come off well. The guys who manufacture the slate actually re-roofed as there was a fault with the roof and they couldn't get the old ones off without breaking them.
It never ceases to amaze me how many installers don't use experienced roofers, but we're not one of them, the slates even beat the manufacturer!
Reply to Roof anchors in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi wondering if you could help with some advice Been running an Essex/suffolk based electrical firm for last 20 years, mainly light commercial...
My best mate has been medically retired from the prison service at the young age of 52 and has time on his hands :D He's looking at a 'plug in'...
Hello fellow professionals, I'm currently facing a challenging scenario that involves the integration of solar photovoltaic (PV) systems on roofs...
Customer asking for lighting for range/hob as it is really gloomy at night. Issues being getting power there, and the curved profile which is...
J
Hi, I take of of 2 rental units. I try to do everything. Plumbing, electrical, roof repair and replace, broken windows and etc. and when I...
