Discuss Running a shed from an extension lead - Part P in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
This is your second post, and I don't get what you mean by illegal.... Unless I'm mistaken, we're not Australia where DIY electrics is actually illegal. DIY electrical work can be perfectly legal and safe in the UK.
EDIT: Just noticed your profile does indeed say Australia, so I think this is the source of your confusion. DIY electrics is not illegal in the UK.
It should be though
[QUOTE="Outofphase, post: 1238070,
My question is, will my shed then be subject to regulations
YES of course it will !
Basically anything that is connected to the mains wiring in any way,
is covered by code.
So you always where covered by code !
You have gotten away with it, simply because you haven't been caught yet.[/QUOTE]
the regs are only up to and appertaining to the fixed installation what is plugged into a socket is beyond the scope of the regs
reg 420 covers this (cant remember the full reg number)
Found this:
Q3: To what types of electrical work does Part P apply?
  • In or attached to a dwelling
  • In the common parts of buildings serving one or more dwellings, but excluding power supplies to lifts
  • In a building that receives its electricity from a source located within or shared with a dwelling, and
  • In a garden or in or on land associate with a building where the electricity supply is from a source located within or shared with a dwelling
I don't know to what extend this is applied. If I roll a normal 13a extension lead out into my shed, powered my install via 13a plug, surely that wouldn't be subject to regs?
I'm not trying to pick holes in the regs, but I'm trying to work out the grey area I've stepped into.
Bluestar, if you could find a source for that information for me to read through, that would be great! I had a quick google search but didn't find anything new.
It would be legal plug a caravan in with a 32a plug wouldn't it? Maybe I need some wheels and a tow hook for my shed.
EDIT: Just to add - I have tested everything with a 500v Megger (all fine), all connections are secure and robust, and no risk of water ingress. All fittings/conduit/sockets/MCB's/wires are new and unused.
Matey.... Part P applies to new circuits, rewires, fuseboard changes and a few other things in England - a dedicated 32A commando socket would fall under this.
As it stands an extension lead "fudge" doesn't
Reply to Running a shed from an extension lead - Part P in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi guys, We’ve had a new CNC Machine from China arrive this week. It came with a monitor and a tower to run the software. The monitor and tower...
Hi guys, I have supplied my Shed with a 6mm SWA cable into a nice consumer unit. In there I have a 6Amp MCB for the lights and a 16 A supplying a...
Hi, I'm looking to get the lionshare of a small shed wired before a friendly electrician does the needful. I'm a confident DIYer, but I would...
Hi all, Curious one and hopefully some one of you could give me some advice. A customer has had a steeltech shed installed at their premises. A...
