Discuss SCR dimmers/light modulator in the UK Electrical Forum area at ElectriciansForums.net
I've got some new LED slimline downlight panels that are supposedly dimmable but need SCR dimmers/light modulator and not a PMW dimmers/light modulator. From the badly translated instructions.
I don't get too involved with lighting and the only SCR dimmers i know of are big ones. These three lights are 6w each.
Surprisingly my local wholesalers have no idea either, can anyone please advise what i need?
I expect 'PMW' should read 'PWM' = Pulse Width Modulation, the normal method of dimming DC. While an SCR dimmer (which would officially have two separate thyristors / SCRs instead of one triac but the effect is the same) is a phase angle dimmer for AC. So my reading would be 'Use an AC phase angle dimmer, not a DC PWM dimmer'. Reference to SCRs might also mean they expect a leading-edge dimmer as all SCRs are inherently leading-edge.
Reply to SCR dimmers/light modulator in the UK Electrical Forum area at ElectriciansForums.net
First off, I'm clearly not an electrician and I'm sure the answer is simple, but I didn't want to go messing with the wires without being sure. I...
Hi guys, I was hoping for some guidance in installing a light switch. This is my first post, so I hope this is in the right forum. In my...
Hi all I am a newbie from Australia to this great forum. I need some advise with wiring up a dimmer and switch for my LED Down lights in...
21K
I need to augment the underground supply to remote workshops at my own house. I’m struggling to understand the practical implications of voltage...
