Discuss Scratching head in the UK Electrical Forum area at ElectriciansForums.net
Ok no one will get this....... I've got a old wiring system with an old house black and red.... right in the kitchen I want to change my old strip light to a strip light but in led... upon disconnecting the old strip light I come across 4 cables each with black and red wires.... now only one cable of the 4 is live the rest are dead.... if I put 3 of the cables lives red together and 3 of the earth cables together black I get the lounge light working front room and hallway working luvly... so it leaves one cable remaining thinking great got to be the kitchen light wired it up but dead???? now if I put the red wire with the other 3 wires the black becomes live of the 4th cable????? So I tried the black witch is now live in the new light brown n blue and the earths from the 3 together yes theres light but no light switch... help..... do i need an led with a ballest to work off the switch or am i wiring up totally wrong?????
We will get this as it’s a very common DIY problem. Search for three plate wiring as were not permitted to have step by step instructions on this form.
You wont need a Junction box no. One red and black will be a switch wire, one red and black will be a feed in and at a guess 2 red and blacks will be feeds out. Google 3 plate lighting wiring diagram and just imagine it with you having a additional feed wire (guessing thats what it is).
Im not going to step by step guide it.
Thank you for your time I shall get it one day lol I'm looking now
Sound like you have a live in, 2 lives out and a switch wire.
Your post doesnt make much sense, can you try and format it a bit better and you might get a more detalied reponse.
If you have now disconnected the fitting and all cables are floating about you need an electrician. If all cables have red and black cores we cannot predict which is the switch drop.
Thank you much appreciated
As Cher sings....tel.
Bang, bang, the first one's down,
Bang, bang, the next one's down,
Bang, bang, that awful sound,
No bang, the switch wire's just been found.
Na nah nah nah naaaah nah....
Reply to Scratching head in the UK Electrical Forum area at ElectriciansForums.net
Hi all was having a problem with lights work one min not next took ceiling rose cover off to find a stray black wire only terminal free is the...
I have 2 lights connected to 1 switch. I installed a led light fixture on one light, it had one red wire and one black wires. It was easy to match...
Hi, I'm looking to install a new bathroom extractor fan in my bathroom as I have a windowless bathroom and the current one I have installed in...
Hi all. Removed an ancient light fitting, replaced with a newer one, the light comes on but can't be turned off with the switch. It was working...
