Discuss Security light. in the DIY Electrical Advice area at ElectriciansForums.net
Yammi
Hi all, I've just fitted a basic security light on my house wall with a automatic sensor. The problem that I've got is fitting the wires. I have connected the live neutral & earth as in the diagram. The problem I've got is that there is one more wire left which is yellow but not sure where this goes. I have a switch inside the house which does not work at the moment so the yellow wire must have something to do with that. The light works fine just need to fix the other wire but unsure where it goes, any help would be appreciated.
cheers Phil.
I am sorry but we cannot really tell how the light was wired originally, it may be the yellow wire is a manual override. If the light is working OK with out this connection then, after turning off the supplying circuit and checking that all the wiring at the light is dead with an approved contact voltage tester, the yellow wire could be terminated into a wago connector inside the light fitting.
Thanks for the quick reply. I have checked the yellow wire and it is not live. If I remember right the old light had four connections for all 4 wires, but on the more modern light like this one there is only three conection red blue & yellow/earth. Like I've said the light works how it should except I can't use the switch inside the house unless the spare yellow can be connected somewhere.
cheers Phil.
Some security lights have four terminals, the last one normally being labelled L* or L1 and this is a direct connection to the lamp for a manual override or connection of a second light to the system.
Other lights like yours only have three terminals, for permanent line, neutral and earth, they do not have the terminal for a manual override connection.
Thank you for the reply. I will make sure to get a four terminal connection the next security light that I fit.
Reply to Security light. in the DIY Electrical Advice area at ElectriciansForums.net
Hello everyone, hope all are well. I'm changing a ceiling rose and have lost the diagram showing where everything was connected (to the old light)...
I have a strip light in the kitchen operated from a single switch. I want to replace it with a straight bar 4 spot array. There are three supply...
Hi I've been planning to fit an outdoor junction box at the front of my house to hide a large brickwork hole and properly house the wiring...
I have a Security Light on my patio and until recently it worked fine. It stopped working and I couldn't decide if it was the LED Floodlight or...
A rose in my 1970s kitchen ceiling became loose (one fixing screw had been inserted right on the edge of the hole in the ceiling) and when I...
