Discuss should I email a reading today? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
P
provr6
I believe the rate increases tommorrow to 45p. I've not yet gave any readings apart from my comissioning reading.
Do I need to email one over or just record the reading for later use? I've not been sent any details yet when my readings are required.
I called British Gas about the very same. My reading is due on the 11th May.
They told me they don't need a reading as their software would calculate an approximate amount before and after 1st April.
Considering April has been especially good then I guess that some of those units could end up at 45.4p and not 43.3p. Still, it's not going to make that much difference anyway.
My FIT provider is Scottish Power, who are using a similar method of calculating the reading. I imagine there will be winners and losers here, depending on when your quarterly reading dates are and the weather. I'll certainly be taking a reading at close of play today and comparing it with SP's estimate.
OFGEM's Guidance for Licensed Electricity Suppliers doesn't seem to prohibit this dubious method of calculating FIT changeover readings ( http://www.ofgem.gov.uk/Sustainability/Environment/fits/Info/Documents1/FIT Supplier Guidance.pdf - section 5.17, page 41)
Reply to should I email a reading today? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Fluke MultiFunction Tester 1662 TNS Earthing system. Switchboard - 415v - 3 Phase + Neutral + Earth. MCB 1000A 3 individual Earths (185mm)...
Slightly strange one this, replaced a few socket fronts in a dining room today, all wiring original but new plasterboard on a studded wall. Its a...
I am in a bit of a pinch at the moment and trying to argue a massive amount of used of electricity with my provider which I find it hard to...
Maybe I've just been lucky, but I very rarely have an issue with customers paying, the vast majority have paid straight away or within a few days...
I am writing to express my strong interest in joining your esteemed organization as I embark on the next phase of my career in the field of...
