Discuss Show us your consumer unit. in the UK Electrical Forum area at ElectriciansForums.net
westward10
Staff member
Admin
Supporter
So a bit of fun as it is a bit quiet. This is mine been there since I moved in and has all the required notices and selected additional protection. The first Proteus one wins the wooden spoon.
Is it caked in notices :)
[automerge]1570902970[/automerge]
How come some are the compact rcbos.
Had a BG when I moved in:
Got off my bum a couple of months ago and replaced with Wylex full RCBO ready for getting our bathroom done so I can fit an electric shower.
This is mine, looks like a snakes wedding and needs a good tidy up. Apparently it was installed in 2017, the inside looks even worse. No installation certification or anything, slowly getting round to sorting things out a bit at a time.
View attachment 53101View attachment 53102
Things that bother me.,... The tails gland compression nut being left off, the supply cable sheath connection, the tape holding the cover on the Henley block, the 100A switch that's doing nothing, the board being BG, all the unsupported cables.
Otherwise exemplory.
I know; and that’s before you even take a look at the inside of the board?
You can also see where they conveniently left the compression nut on top of the 100A isolator that contains a 15A fuse inside; which in turn feeds a 3A FCU in the hallway for the burglar alarm.
Let’s not get started on how they’ve secured the the earth to the TNS lug using a bonding strap.
Some people churn out some right tripe, don’t know how they get away with it.
[automerge]1570908825[/automerge]
That 100A switch is a redundant by the look of it Memera 2000 consumer unit.
It looks redundant, but after some digging round I found it feeds the house alarm. Difficult to see from the pictures and only got 15A fuse in it. Fed directly from Henley blocks with no RCD protection from what I can see.
Yes it was between old ceiling and new false ceiling with a small hole to access fuses.
Top left you can see the whole, the consumer unit bottom right only served the flat, now replaced with one consumer unit all RCBO but still means if anything trips, it's a walk around outside of house down a set of steps to the granny flat under the house to reset anything.
I'm gonna have to move some steps and stuff I think. Kinda squished in there with the phone can you see any of that?
Reply to Show us your consumer unit. in the UK Electrical Forum area at ElectriciansForums.net
Hi all, what is the best way to configure surge protection in domestic dwellings when you have multiple consumer units? Does each consumer unit...
4K
Hi, Hoping someone can clarify for me. I've recently moved into a rental property, the landlord had new electric radiators installed and a new...
Just looking to see if anyone’s had a similar job or has any other ideas. Got a consumer unit to upgrade, the current one is fitted inside an...
I had a consumer unit replacement today. It was a bit of a nightmare as most of the cables were too short for the new unit. I extended the ones...
5K
