Discuss shower priority unit positioning in the UK Electrical Forum area at ElectriciansForums.net
I don't see how that will help.
Using a 3 pole mains switch would isolate all circuits.
Using a contactor would isolate the outgoing shower circuit.
Using a CT relay at the House would mean you could also limit other circuits if there was lack of capacity.
a contactor will normally turn off a circuit but i would not consider it isolated.
not trying to be pedantic but we should use the correct terms for things as professionals so that we leave nothing to the imagination or interpretation of our words.
unless of course you think a contactor is a suitable means of isolation and then i would just call you out as Wrong.
Why not ?
What term did I use that was wrong ?
Table 537.4 60947 contactor isolation = yes
No more debate ?
Ok.
I'm thinking a contactor has a control circuit, which would operate said contactor. Whereby you could isolate the control circuit. But does that safely isolate the circuit, like a standard isolator would do. What does BS7671 say about isolation?
Ok.
Bs7671 gives guidance on what can be used for Isolation, emergency switching and functional switching.
I have not got time to look in depth into it.
however my thoughts, right or possibly wrong as you have pointed out.
An isolator is a means of removing power from a circuit to allow amongst other things, work to be safely carried out on it.
a contactor by its very nature may bring power back to the circuit if it receives power to the coil, this may be from an automatic device like a thermostat or a remote switch.
I for one, would only rely on a contactor for isolation of a circuit i was working on under some very specific circumstances. and also, I have yet to see a contactor that has a means of locking off.
Reply to shower priority unit positioning in the UK Electrical Forum area at ElectriciansForums.net
Hi. I'm being tasked with installing an electric shower into a property that was built back in the 1980's. The main consumer unit has only 4 ways...
Electrical2Go - Beginners Guide to Positive Input Ventilation (PIV) Units: A Solution to Indoor Air Quality Woes A guide to Positive Input...
Hi I've got an new outbuilding that needs power run out to it, the building is very close to the house and the original plan was to run an...
Hi All Let me start by saying I have my 2365 level 3 but never worked in the industry so my knowledge is limited. My partner and I recently...
