Discuss Shower probs in the Industrial Electricians' Talk area at ElectriciansForums.net
B
BEN5637
hey guys, wondering if i can call on your advice re.Basically I have just done a new cu/peb and lighting circuit re-wire.customer has now has bought a 9.5kw shower and wants it fitted he has a 60A main fuse. he has the usual up/down rings, 2 lighting circuits, cooker, immersion etc. is this ok or not to put another 40 or so amps on the installation. i reckon a 7.2 on 6mm and 32A would be better am I right? many thanks lads.
Hi. Just a thought but can you not get the electicity company to upgrade the main service fuse to a 100A and possibliy the upgrade the main tails (if required). Problem solved?
You need to look at the diversity of the house(look in on site guide) . you will probably need to get the board in to up the company fuseto 100A , up tails from 16 to 22mm from suppliers fuse to meter and you would be responsible for the tail from the cut out to dis board.
Mike
sorry a repeat savaly beat me to it.
Gotta be honest i wouldnt worry too much.
Its unlikely that, with a bit of diversity (although this is not strictly correct) that the installation would pull 60A. They can run all day at 60A+ and not have problems.
If you do go for an upgrade to a 100A (some DNO's do this for free, but not all), they sometimes use an adapter that sits over the existing carrier. Just make sure you have the depth in the cupboard before hand.
And yes, upgrade the tails. They are probably old cloth braided anyways.
Reply to Shower probs in the Industrial Electricians' Talk area at ElectriciansForums.net
Hi, I have a client with a small caravan site, approx 5 hookups. His old toilet block was nothing much more than an old shed. He's now 'upgraded'...
The electrician that installed my cooker circuit put in 10mm cable with a 32a fuse, a 45a cooker switch and 10mm cable to the backplate for behind...
Hi I have a job where customer has two families one families lives upstairs and one family will live downstairs. As the property is going through...
Hey all, Ive been in and out of a huge house rewiring as the renovate it for a year of so. Every is thing done and dusted except the downstairs...
Hi. I'm being tasked with installing an electric shower into a property that was built back in the 1980's. The main consumer unit has only 4 ways...
