Discuss Single cu change Bonding cable to gas then water broken in the UK Electrical Forum area at ElectriciansForums.net
bleach
Hi people, I'm due to do a cu change and noticed the single bonding cable to gas then to water but it's in two bits of cable. Am I right in thinking that it have to correct this due to cu change? It would mean running another cable which is annoying as gas and water are about 18inches apart but the existing is not long enough grrrrr!
Reply to Single cu change Bonding cable to gas then water broken in the UK Electrical Forum area at ElectriciansForums.net
Been looking at a CU change in a small office and would appreciate comments on the following. Office is supplied from the mains intake in the...
6K
Hi all, I am looking for some advice regarding old rewireable (3036) fuse boards in regards to additions and alterations. I am an electrician and...
4K
Just had a boiler put in on a grant scheme. Water main earth bonding was connected in with the existing gas bonding's pipe clamp on the outlet...
6K
I have a customer with a farm who has a barn containing a large 3 phase generator which powers various equiptment at that location. A single...
Hi guys Does the earth Bonding HAVE to be done at the meter or can it be put on the gas inlet to the boiler in a utility room? Plans have changed...
