Discuss Sky magic eye problem in the FreeSat, Sky, VirginMedia Forum area at ElectriciansForums.net
U
Unregistered
I have replaced my sky magic eye with with a new one as the old one had come apart. I have sky+ downstairs and two tvs running from it upstairs via coaxial cables and a booster all installed by tv company years ago. All was working fine until i changed the magic eye. When i plug it in to the tv/coaxial the little red light comes on. As soon as i press any button on the sky remote the red light goes off and nothing happens. I have tried a working one from the other bedroom and that works fine (its a different brand). This is the second replacement magic eye i have had surely they cant both be faulty.
it is strange the red light comes on an stays on until the remote is pressed.
Help
thanks
id double check you havent got any short outs in the co-ax cables first, but i assume its a specialised booster for the job as a standard booster may have problems with the signal voltage sent up from the sky box, you can always take the booster out and run one tv just to see if booster is failing, just a matter of trying different setups to locate problem, try you good magic eye on same tv you have the trouble with.If you using another brand of magic eye they may not be compatable with booster thats why i suggest taking it out of loop and see if it solves the problem.
the one i am using on the other tv which is working, and works on the tv with the problem one is a labgear digilink one which apparently is now obsolete. What I cant understand is how the labgear one works fine on both TV's. The other one has the red light on when connected to both tv's but when you try to use the remote the light goes off.
Bizzare
Reply to Sky magic eye problem in the FreeSat, Sky, VirginMedia Forum area at ElectriciansForums.net
Hi I have a Corby 7700 trouser press it is a 220w model, 3 years 10 month old. On Friday it stopped working, so I took it to the garage ready...
I have a ceiling fan that never worked ever since we bought the house. Only the light worked. One time I had a friend of mine come along with some...
90s house electric issues continues 🥲 So after getting some good advice here I've managed to sort out some of the heating issues so thank you...
Hello everyone. I have a inverter configuration problem I thought someone here might be able to help with. I'm not looking for a specific solution...
Extremely low voltage on 120v line Hi, I’m not an electrician but my home has 20 amp breaker that has only one outdoor outlet on it with a GFCI...
