Discuss SMA Bluetooth Wireless Monitoring Device Problem... in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
synergy power
Hello everyone,
I'm having a few problems with linking an SMA wireless bluetooth monitoring device to an inverter.
The inverer is an SMA SB 1700 with a piggy back bluetooth module installed.
I have set up the device using netID: 2 on the piggyback module.
I can get the laptop to connect to the inverter using Sunny Explorer but when i try and connect with bluetooth wireless device to the inverter it does the following.
I go on settings, PV Plant, new plant search, start detection.
Under plants found it says 'NetID: 2' so far so good i presume?
I then click and go onto the next screen, where it trys to establish a connection with the plant with NetID: 2 although then no devices are found?
Can someone please help me try and solve this problem. All the help will be really appreciated!
Thanks, Ryan.
have you changed the password when in sunny explorer?
double check the password on sunnybeam anyway, should be 0000 to start with, but we always change the passwords to avoid the chance of people playing silly buggers with the system.
Reply to SMA Bluetooth Wireless Monitoring Device Problem... in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Ferrets are known for being small, resourceful, and incredibly clever. They can solve many problems by fitting into tight spaces and doing jobs us...
Ok, i am new in this forum I am looking for some enlightenment. Today I got a call from my boss, which is now in Venezuela and he is connecting a...
Hi all, total newbie to the forum. I sincerely hope that those in the know-how would be able to assist me. On my semi-detached house we have an...
I have a client on a Superdeal tariff from SSE, the Superdeal Meter has 3 sets of tails coming out of it feeding 3 DBs: (i) DB1 - the main board...
Hello Please help me to understand more about the kinetic switch! i have 6 quinetic wifi wireless receiver for dimmer switch (1AMP)and 3- 2 gang...
8K
