have sma 3600tl inverter, done tests on each individual panel as installed also each string when connected
together got results.
then see my meter solar 150pv tester you can also plug into string when connected to inverter, just wanted
to know if i can connect at inverter point for each string as 3600tl has 2 connection points for each string to do
tests? or do i have to join set of test leads in at dc isolator & do final tests?
i know inverter gives readings for power, current & watts for both strings one at a time & could take these as my final readings, but would like to take readings also with solar 150 as then i can save them to file electronically
& put them into electronic test sheet. just did not know if that is possible or could it damage inverter in theory
same could be said if i do the tests in parallel with inverter after isolator?
just newbie to solar any help would be much appreciated
