Discuss Socket height regulation in old home in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Height only applies to current new builds so not necessary. If you are stripping out the whole house and having walls chased etc for new cables you might like to take a view on socket positions being at a more accessible height? I take it the current sockets aren’t in the middle of skirting and an inch off the floor? 😜
No they are about inch above skirting. Walls are concrete so I’m having truncking
Sockets must be at least 18" in height off the floor reg IEE
Hello raylec.
It hasn't been the IEE for quite a few years. It's the IET now. The regulation height of 450mm is not in IET publication of BS7671 I believe. Always happy to be corrected though.
You'll certainly find it in the government publication of the building regulations Part M.
Part M is for new builds but also for buildings undergoing 'material alteration'.
Part M then goes on to say (in a complicated way of course), that if the building is undergoing material alteration it can not be any worse than it was.
So basically, you cant make the sockets lower than they were before, but they can be the same height..... usually, unless they were so low before (skirting board) so as to cause mechanical damage, then they should be raised (Reg 553.1.6)
Hello raylec.
The IET 'Electricians Guide to the Building Regulations' does specifically say that Part M does not apply to rewires.
That said, if you're doing a full rewire, chases etc then I can see few compelling arguments to not use the 450-1200mm zones regardless.
It's ugly as hell having sockets halfway up the wall.
It makes the light switches far too low and they can easily end up being blocked by furniture.
On a rewire you can often reuse some locations, expecially for switches, and reduce the damage by not changing the height of the box.
Blimey, I'd have thought it would be the other way around.
The problem is with the flex exiting the bottom of the plug. With a flush socket, the flex will exit just above the skirting, which would be fine with an oval 0.75mm2 twin, but with a 3C 1.5mm2 flex, the plug will be being forced out at the bottom or twisted.
With a surface socket, bringing out the plug another 25mm or 35mm, the thicker flex will be able to hang straight down, over the surface of the skirting.
It will be much more vulnerable to furniture being moved about on a surface socket, but the regs don't really cover that.
Reply to Socket height regulation in old home in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi there, I am looking for some advice re: putting new sockets and usb sockets in my home. Someone will be rewiring the entire house but I have...
Hello All, I am a homeowner (but not an electrician) and I am renovating a house that has an old CU containing MCBs and an MK LN5725 residual...
Hello, Last year I had some electrical work completed in my house (New CU, SWA for garage, downlights) I informed the electrician that I will be...
Hi all, First post here, hope I'm compliant with the rules! I did do a quick search before asking this, but I couldn't quite come up with the...
