Welchyboy1
1,039
1,036
1,688
45
Essex
United Kingdom
Does anyone know the socket size i need to fit the head of the driving nut for a 5/8 earth rod please?
thank you
t5ry a few till you find the right one.
Reactions: 2 people
Measure it
Reactions: 1 person
thank you
1inch is 25.5 mm so 13/14mm will work
universal earth rod tool.....
Reactions: 2 people
The "driving head" is whatever you fit into either the socket (usual) or the threaded end,to protect it from the impact forces of your driving tool/hammer/fist. I have an adapter that fits neatly over a 13.9 capscrew and fits into driving cup welded to a steel 'bit',that is driven by my old modified Hilti TE72. The capscrew is tough enough for several sessions unless you find a hard raisin in your pudding...i could tell you the size of my capscrew,but i would then have to ritually disembowel myself with a turks' dirk...the size of which is ALSO,a secret :thinking:
thank you
The bolt I have here (that fits into a 5/8 coupler) has a 1 inch hex head, if that is what you mean.
Reactions: 1 person
My driving stud which I've kept for years has a hex socket in the top of it rather than a bolt head, I think it was a 13mm Allen key before it got beaten to buggery with a hammer.
I use the E54 technique, just stare and growl for long enough and wait until the rods stop quivering when they reach 1Ohm.
Essex
United Kingdom
Socket size for 5/8 earth rod driving nut
Welchyboy1,
netblindpaul,
