Discuss Solar/Battery powered security lighting in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
I
IanC
Hi There,
Can anyone recommend any solar or battery powered PIR security/flooodlights?
I need to illuminate the end of my garden which is pitch black in the evenings and not very safe. I would rather not have to dig a 35m trench to lay cable. I have searched the net with no luck as of yet!
Any links or advice would be appreciated, thank you.
You might want to think through solar/battery powered security lighs. assuming one 500 watt lamp, this would need more than 40 amps from a battery supplying a 230 volt inverter. This battery would need a fairly substantial solar array to provide sufficient power to run a 600 watt inverter.
You need to determine your total demand and from that the watt hours that your lamp will actually work. If you can give me a better idea of your requirements I can help you with the estimate
Reply to Solar/Battery powered security lighting in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi. I'm an I.T.. engineer with some outdated electrical experience. I qualified C&G 2330 17th edition about 15 years ago, but my only experience...
Hi, Recently had 3.6kw solar installed, at the time shortage of batteries & roi figured batteries not quite worth it. thinking otherwise perhaps...
I am a retired Electrician and started looking at Solar Power, (Black Magic to me), after much reading of "How To", I decided to build myself a...
Hi all. We have had 7x 400w solar panels for a number of years now on our roof which is se/nw facing end terrace. 4 on se side 3 on nw side...
So, I already have solar (an older FITS installation) and it's been particularly successful so I want to extend this. I'd like to do two things at...
