T
tm.electrics
Hi all i install these in northern ireland for a company and i met one of the inspectors who was inspecting my install , he said it will get failed due to there being no ac isolator at the consumer unit even though there is one beside the inverter, his excuse was if you needed to work at the isolator you couldnt isolate it! i replied what if you need to work at the isolator that supplies the isolator? is this not a bit redicuolous? Also it was not controlled by rcd which again i pointed out about tripping times etc but he knew about this and just said power supplier asks for it. he also said all inverters need to be mounted on fireboard which i wasnt aware of ? what does everyone think?
