- Jun 2, 2018
- 485
- 354
- 101,238
- If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at?
- United Kingdom
- What type of forum member are you?
- Practising Electrician (Qualified - Domestic or Commercial etc)
Can anyone advise when SPDs are required to be installed on commercial properties?
I'll always install them on a full rewire of a commercial property or if I need to install a new DB, I'll make sure to fit one with an SPD installed.
What about if its a large store, 36 to 72 way existing board but with no surge protection and they require an additional single phase circuit to be installed. Should we be fitting an SPD? This could potentially double the cost of needing an extra circuit installed.
