Discuss Swa through scaffold in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
My work is erecting a scaffold as part of rough cast project.There is a SWA on the house which is enclosed in steel capping.
Does the scaffold require to be earthed as under fault conditions the scaffold would become live?
It might be a concentric cable so my understanding of this is that if the cable was to be damaged then the earthing of the cable would be too therfore creating an earth path similiar to SWA so would the protective device not operate under ADS anyway?
Or because it is an extraneous conductive part should the scaffold be earthed regardless.
Seems resasonably specialist if there is a guidance note for scaff as above ^^
But I always ask myself 2 questions. Is it extraneous or part of the electrical installation. If yes to either it's required.
SWA enclosed in steel capping, sorry mate don't understand why would someone install a SWA and
Reply to Swa through scaffold in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
It seems to be easy, these days, to buy fittings (often containing resin) that allow someone to tee into a pre-existing SWA cable. Some of these...
I have had a kitchen extesion built on an old property (c.1810), which has an unusual consumer unit situation. Part of the property has only a...
Having a bit of a brain freeze moment. I have a 2-core SWA cable running to an outbuilding. The sheath is used to earth this cable back to the...
