Discuss Terrible kitchen install in the UK Electrical Forum area at ElectriciansForums.net
If you stick around long enough here, your find some members here feel that's the only way to do it :)
nah, all old hat that FCUs and grid switches. i use wireless appliances . no plugging in. just place in position and programme to connect to wi-fi.
Usage of these two types of back boxes below would have resulted in an appearance more pleasant to the eye. Usage of a spirit level or line laser would have ensured a perfect finish. There really is no excuse for such lazy, sloppy workmanship. Whoever did this merits a hard kick in the gonads.
The customer gave me the "electricians" Business card with his Facebook page on it, was surprised when I saw who his previous employer was, a well know well respected company who would not be impressed with his workmanship.
Usage of these two types of back boxes below would have resulted in an appearance more pleasant to the eye. Usage of a spirit level or line laser would have ensured a perfect finish. There really is no excuse for such lazy, sloppy workmanship. Whoever did this merits a hard kick in the gonads.View attachment 41591 View attachment 41592
Unfortunately, those boxes only work with standard size white switches, etc. The brushed metal ones the OP has are wider than the standard.
As above, some 20mm bushes may be a solution, or just plain care and workpersonship.
I always leave a box width between boxes this way it overcomes the issue of the socket plate sizes, allows plastering etc between boxes and if slightly unlevel sometimes not so noticeable. They should have left as grid switch. Hopefully, there is a bit of giving on the K.O. box.
New posts
Reply to Terrible kitchen install in the UK Electrical Forum area at ElectriciansForums.net
I have a double oven connection unit. Fed with 4mm cable,40 amp MCB. Hob connected to it with 4mm cable. Bought new oven,stated 16 amp but with...
I may have posted this before but not sure if it made it in. I want to install an EV Charger in my garage. The panel is two stories up and the...
Hi, I've searched these forums and have found quite a bit of good information, but not specifically to my query. My house is about 9 years old...
