Discuss Testing Ze using robin tester in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
S
Stress head
Hi recently purchursed a robin kmp 4116dl. It's came with no instructions so unsure testing Ze if it's a 2 or 3 lead instrument.
Thanks in advance
hawk81 im a trainee electrician , and i only do like for like fittings, pat testing, odd extra light so on, as you know electricians dont want any help at mo..
Thanks in advance
Iv got a ROBIN KTS 1620 i downloaded the instructions from kewtech as they bought them out and now there just re branded same meter.
If you ve got 3 leads you use 3, If you ve got 2 use 2. The 3 rd will be live and you dont want it dangling about :)
Hi
use the 3 lead for ze,zs,pfc,psc,rcd and then use 2 lead for continuity,Insulation testing you should have 2 sets of leads the set with 3 wires should be fused and the set with 2 unfused when using the 3 leads they will all be live testing so please take care my friend as that invisable thing called electricity stings
cheers
Rich
Kewtech instruments used to make identical machine to the Robins, and there instructions were identical as well, so try a download from kewtech.
Try emailing Fluke, as they own Robin, or they used to.
Cheer...........Howard
Reply to Testing Ze using robin tester in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
So, I was messing around yesterday with some old testers I have laying around to see if they still work I found my dads old Robin MFT and noticed...
Hi all, We have a limited in house PAT testing requirement and were advised that the TIS700 fitted our needs. The unit works fine for 110V and...
Hi, while carrying out an EICR at a farm cottage on Friday i came up against a problem early on. Whilst measuring the Ze the reading i obtained...
Electrical2Go - Megger MFT Deals! Upgrade your toolkit with our exclusive offer! Purchase any of the Megger advanced multifunction testers –...
