Search for tools and product advice,
Discuss Three Phase Sauna in the Electricians' Talk | All Countries area at ElectriciansForums.net
R
Robert Casey
Hi, I was wondering if I could get a little advice off you guys. I'm installing an three phase 8kw sauna over roughly a 50m run. The board is a typical 20-30yr old three phase commercial board with no rcd protection. I'm thinking 5 core 2.5 swa for the cable up to the sauna then into some kind of box or isolator and then down in 5 core 2.5 flex and into the unit. What I need help with is I guess as there is water involved it will need some sort of rcd protection. I'm wondering if someone could advise me on what isolators and or rcds I will need. I don't work with three phase too often so any any advice would be appreciated as I have to do this correctly for obvious reasons. Thanks!
Rooms containing saunas are "Special Locations" and as such the work is notifiable if this is in domestic premises. Section 703 in BS 7671 (page 179) covers the additional requirement necessary for rooms containing saunas.
For gods sake you're entering a minefield blindfolded.
Spend the W/E reading the reg’s before you kill someone on Monday.
Please pass this job over to someone that knows what they are doing!
I'm not being nasty, I’m trying to save your skin from the lawyers!.
Reply to Three Phase Sauna in the Electricians' Talk | All Countries area at ElectriciansForums.net
I have a scenario where there is a three phase DB in a commercial property where there are mixture of three phase and single phase washing...
Hello All So I'm not long out of my college days and unfortunately I didn't have a lot of exposure to three phase and commercial wiring systems...
BIG place OK lots of electrical bits. but one on a 3 phase Radial is tripping its RCCB so i check the wiring making sure its tight and it has...
Hi everyone, I have been asked to pull in some new 3 phase supplies for 7 new welders which do not require a neutral connection. The client has...
Hi guys, could someone help with the following please? The scenario is: Domestic property supplied via three phase (with a 3P main DB, NO SPD)...
