Discuss torque drivers in the UK Electrical Forum area at ElectriciansForums.net
J.C.E
Afternoon
Had my annual niceic assessment today (only DI mind)
Showed him a rewire I done few months back- literally had nothing to 'pick at'
only thing he said is when I was un-screwing the mcb to get end to end reading- I just used a normal screw drive- and I should be using a torque one
any of you guys recommend a decent one to get- don't mind spending a bit for something decent...
cheers
SBS Dave has them for £35 and a fiver a blade....TBH I wouldn't go all out on one as the only time its really going to come out is at assessment time.......Unless your limp wristed:D
Edit: The blades also have extended tips for getting in to RCBO's etc.
never stripped one in 50 years of sparking. split a few MCBs though.
was know body your assessor or just ksome body?
Had my afternoon with Stroma late last year and nothing was said during the check session. I do have some now (Xmas prezzie) and I'll be wanting to show them off this year.
Totally off topic but reminds me of people getting words mixed up, a few years ago did the electrics for a fairly wealthy couple when they revamped their lounge- they even had an interior designer on board. Part of this was a huge flat screen telly and fancy sound system , so I ran in some thick speaker cables to the planned positions at 1st fix stage. I never corrected the old boy but several times he referred to the two 'large woofters' that would be in the corners either side of the telly. :D
your write their pete, I joined niceic in 2005-2013 with elecsa up to present .
with niceic they start nit picking . might join stoma next year
took a bloody long time to join, 8 years. did your cheques bounce?
Reply to torque drivers in the UK Electrical Forum area at ElectriciansForums.net
I was working alongside the plumber yesterday. I had to drill some 32mm holes through joists. I always use my Makita 481 high torque drill will a...
Hello ! I am building for some time a cct to drive a 3digit multiplexed LCD. (from aliexpress) From the sellers on aliexpress I managed to find...
A friend of the family recently lost her husband to the big C so I need to be careful. Every small thing is sending her into tears so when her...
Just thought I'd share this quick sobering story that happened to me a couple of weekends ago.... Overhead 230v lighting festoon, LED golf ball...
I found myself needing to do some emergency plumbing at home this evening. I've got a small guest flat on my property which has been empty for...
