Discuss Tray & basket install in the UK Electrical Forum area at ElectriciansForums.net
cliffed
Supporter
Been helping on site with a couple of electricians,nice job really,but why use cable tray,surely basket is the way.
not sure if basket will take the weight of many heavy armoured cables.
tends to be used more for data cables etc.
Possibly depends on the support c/c, tray can span a greater distance and is able to take more weight, one assumes it's been designed that way?
(typed at the same time James)
Tray being used for T&E lsoh install,no Swa’s.
Basket is for data,I think cables look far better in basket,tray not having the depth can look untidy.
[automerge]1581618763[/automerge]
I was told always tray for armoured and basket for twin and earth / flex / data cabling etc
Defo
Defo
Why n0 SWA?
Basket is so much easier to bend and manipulate, no need for manufacturers bends, cut ends can be filed down easier, bolt cutters and a file is all you need.
Pretty bad installation in fact, sharp edges and not using the manufacturers T's and bends, I would have it taken out and re-done correctly.
But will not take the weight that a tray will, horse's for course's as they say and what it looks like above a false ceiling or in a plant room is so important.
Not having a laugh at all, been in the industry for over fifty years and seen professional electricians make something that will suit the situation without all the sharp angles and edges.
Reply to Tray & basket install in the UK Electrical Forum area at ElectriciansForums.net
There are electrical engineers who just mutter the slogan "Safety is the top priority," and simply convey old and inaccurate Cable Tray Weight...
Hi everyone just joined the site Iam a trainee electrician currently have my 18th edition and doing my level 2/3 diploma I have been working...
I am trying to find how to price per meter for installation of cable tray 150mm x 150mm for a large commercial project.
Hi all, Thank you in advance... So I had an electrician put in some FCUs on spurs to a couple of outside lights.. this one was in readiness to...
Hi, I'm installing a Hoover oven and would like a little help please. The oven code is HOC3158IN. The oven manual states "The power cable must...
