Discuss TT system enquiry in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
C
chainsaw
Hi Guys
I have just had a large steel I beam installed across the width of my house and supported by another, do these have to be integrated into the earth bonding or not???
Also I am going to remodel floor plan and was wondering if it is ok to use metal partitioning and if so will this have to be earth bonded?
Thank you for your wise and respected answers in advance.
Regards
Welcome.... re the steel and the partitioning, I would say check with the spark who is going to be doing the electrics......
Ive bonded my steel tool box and supplementary bonded my steel ruler to be on safe side due to no rcd protection on the tool box
...I did me nans titanium hip joint,and managed to obtain some flesh coloured 6mm for the inner leg run...she's exstrangeous :artist:
Reply to TT system enquiry in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi, I'm having a new boiler fitted in a new location. I need to provide power for the boiler which I'm looking to do myself. Boiler: Ideal Logic...
Evening everyone . Currently looking at pricing a job up . It’s a hot tub supply . Outside socket with a few spare ways in an outdoor cu . 10mm...
TNC-S main supply with 16mm swa supplying garage consumer unit from main consumer unit in house, then 4mm swa supplying pond equipment through...
Hi everyone, I'm nearly on my AM2 test and really enjoy the industrial side of things so I thought I'd learn by asking. I recently came across...
Hi all, I have two questions regarding wiring and containment on commercial property stairwells in Ireland. We are currently wiring a 3 story...
