Discuss twinflex fire alarm fault. in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
M
Michael0703
Hi,
needing some advice with a 2 zone twin flex fire alarm panel.
The panel is showing a power fault which is obviously the batteries as the voltage is only 19volts, but the panel has also shows a fault. See attachment.
Looks like it's indicating zone 1 in test mode.
You have a power fault also. The fault light is general for all faults.
You will still need to take zone 1 out of test mode
Reply to twinflex fire alarm fault. in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Daughter has bought a house and it has a home security system, G-Tag setup. Issue is the alarm panel displays are pixelated and you cant see...
The big stately home I’ve been working in has an EMS 5096 alarm system with over 100 detectors and 3 (that I know of) panels. All detectors are...
Hi, I need to extend a fire alarm, the panel is a CTEC CFP 2 zone one and currently it has a couple of apollo alarm sense sounder bases/heads on...
4K
Good evening! Don’t have a huge deal of experience with fire alarms but having to work on a conventional system at the minute with various...
We have a domestic fire alarm system in some leasehold properties. The existing BRK alarms are no longer available in the UK. These alarms/system...
