Discuss UK - Socket light switch combo in the DIY Electrical Advice area at ElectriciansForums.net
Do you mean plugged into double socket nearby?New house has wall light wired into double socket nearby.
It's not plugged In but wired into the socket wiring and run up through the wall to the light. Like it's piggybacking off the circuit for the double socket.Do you mean plugged into double socket nearby?
The problem is that you will need to retain the (hopefully 3A) fuse in the plug in the circuit for the light.
If the lighting is wired into the socket (as thr source of supply) then best practice (aside from not doing it in the first place) would be to have a (switched) fuse connection unit, with a suitable fuse and then onward to the lighting circuit, either 3 plate (power fed to ceiling rose first) or 2 plate (power fed to switch first then on to the light.New house has wall light wired into double socket nearby.
Can I replace with socket/switch combo?
If so I can only find cooker switch + socket combo - will this work.
Will post up tomorrow when I get the power off again.Can you show pics of this set-up.
Via pull cord built into light fitting. That's the only switch for it.How is the light switched off and on at the moment?
Hasn't been available for at least half a century, but iirc, MK used to make a cooker switch with a 5A socket, and this had a cartridge fuse on the frontA cooker switch with socket would not be suitable if a fuse is required as it doesn't include one.
This one? (15A fuse though it seems)-Hasn't been available for at least half a century, but iirc, MK used to make a cooker switch with a 5A socket, and this had a cartridge fuse on the front
Reply to UK - Socket light switch combo in the DIY Electrical Advice area at ElectriciansForums.net
