Instyle LED Lighting Specialists UK
Advertisement - Content continues below
Discuss Under bathroom floor rewire? in the Electrical Forum area at ElectriciansForums.net
Hi there,
We have had an electrician work on a fix price job to rewire the house. He has routed all of the cabling under the bathroom floor. I expected that he would routed another way which was more difficult, but wouldn't have gone under the bathroom floor.
Is anyone able to confirm if this is A safe and B legal and up to regs. It doesn't feel right that all of the new circuits run under a area such as bathroom. Thinking what happens if there is an escape of water?
Many thanks
Rob
Andy78
Mentor
This should be perfectly fine. There should be no problems even in the event of an escape of water as the cable runs should not have any joins in them that could be affected by water ingress. Even if water ingress did cause problems to any part of the wiring system a rewire will have incorporated the most up to date circuit protection devices which are designed to prevent dangerous problems.
There are no regulations I can think of that have broken in this method. I would put a light fitting in the room under a bathroom with no worries at all.
I do believe your worries are unfounded.
Rpa07
If you are worried about a sudden escape of water then just make sure that your plumber is better than the Spark - everything will be fine then!
Agree with above - no regs. All underfloors are transit areas for cable runs, it’ll be RCD protected as of 18th edition.
  • #4
Thanks both, appreciate the response.
Sounds like I was worrying over nothing then, it just felt wrong putting wires under a bathroom.
Again thanks! :)
Rpa07
It was only a recommendation - I didn’t say it was possible!
Squid
Fixed priced job and the electrician took the easier route which is all fine and dandy and meets all regulations to be honest, why should he have taken the difficult route?
davesparks
Mentor
Again thanks! :)
Would you prefer to have no lights or sockets in the room below the bathroom?
Matthewd29
Absolutely nothing wrong with it. If I was on a price I would be taking the easier and shorter route too
Reply to Under bathroom floor rewire? in the Electrical Forum area at ElectriciansForums.net
Aico Carbon Monoxide Detectors
Top Bottom
