Discuss Under bathroom floor rewire? in the UK Electrical Forum area at ElectriciansForums.net
Rob G
Hi there,
We have had an electrician work on a fix price job to rewire the house. He has routed all of the cabling under the bathroom floor. I expected that he would routed another way which was more difficult, but wouldn't have gone under the bathroom floor.
Is anyone able to confirm if this is A safe and B legal and up to regs. It doesn't feel right that all of the new circuits run under a area such as bathroom. Thinking what happens if there is an escape of water?
Many thanks
Rob
This should be perfectly fine. There should be no problems even in the event of an escape of water as the cable runs should not have any joins in them that could be affected by water ingress. Even if water ingress did cause problems to any part of the wiring system a rewire will have incorporated the most up to date circuit protection devices which are designed to prevent dangerous problems.
There are no regulations I can think of that have broken in this method. I would put a light fitting in the room under a bathroom with no worries at all.
I do believe your worries are unfounded.
If you are worried about a sudden escape of water then just make sure that your plumber is better than the Spark - everything will be fine then!
Agree with above - no regs. All underfloors are transit areas for cable runs, it’ll be RCD protected as of 18th edition.
Fixed priced job and the electrician took the easier route which is all fine and dandy and meets all regulations to be honest, why should he have taken the difficult route?
Reply to Under bathroom floor rewire? in the UK Electrical Forum area at ElectriciansForums.net
Hi all, I am looking for some advice regarding old rewireable (3036) fuse boards in regards to additions and alterations. I am an electrician and...
4K
Well....wiring in a 1750s thatched cottage attic, not wiring made from thatch 🤪 One we have been letting for over 20 years (as well as enjoying...
4K
I'm starting a new project on Monday, new dental practice conversion from a shop. Nothing new here, customer doesn't know what electrical heating...
Morning All I recently completed my first re wire and board change, (with help from the owner who is a gas fitter and plumper, who works with my...
