Search the forum,
Discuss Velux windows and pv in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi,
Just been out to quote a job and the client is wanting to fill his roof with pv panels and cover 3 velux windows completely. Is it possible to cover all the velux windows? The client said he has had a quote already and they confirmed it was ok to cover them.
It may be worth considering if the Velux units were fitted to comply with Building Regs. If the Velux were installed as a fire exit route in addition to light/ventilation, you could be putting yourself in a very interesting position.
Anyone covering them could be putting themselves at odds with the Building Control people. If you are having the inspector out to approve the install, rather than self certify, you may have a problem.
Personally I would consider this very poor practice. As TonyL states there may be a building reg issue if they are considered as fire exits etc. There's a question on damage to the panel if the velux is opened up as they protrude outwards also. Failing all this its just the general working practice. I certainly would want to look out of a window and see the underside of a panel. The client is just trying to achieve something the roof isn't capable of taking. 4kWp at any cost!
If there is one thing I have learnt in the last 16months of installing PV it's know when to stick to your guns in a professional manner and convey your knowledge to the client. I have and will continue to walk away from potential jobs if I believe the system will not work due to shade or alike or they are asking for an installation that will not fit etc.
Some installers will install at any cost regardless. Lets hope they come back and bite them on the bum!
Why not take them out and re-felt baton and tile over them if they wont be used.
But I would still speak to building control to deal with this matter as I have had to do when I have taken down chimneys in the past.
Reply to Velux windows and pv in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi all - I’m new to Solar PV, builder we do work for has fitted some integrated panels on his garage roof, there is a velux window nearby. Does...
Hi all, I had a conservatory built four years ago and we have now decided to see the house. I asked the builder if I needed building regs and an...
Hi guys, I've gotten AI to write up a terms and conditions for my company and then went through it with AI and tweaked it to make it sound a...
Hi all. Sort of an interesting one. I had a call from a client to say she is getting a shock when using the shower. I told her not to use it and...
I had a PV system installed by a local reputable manufacturer last autumn; since then, I've received conflicting advice regarding the consumer...
